confused.com
  • Thread starter Thread starter davebates
  • Start date Start date
  • Tags Tags
    usa
davebates
hi guys its late and ive confused myself a bit ive got a kitchen/diner to tile the diner side is floorboards (quite solid) but still floorboards and the kitchen side is a really uneven concrete slab its in the same room so tiles will run across both sustrates, so the question is do remove the floor boards and go 15mm wbp across the joist then 6mm hardi,s then pour 2 buckets of leveller on the concrete side to bring it true and flush with hardi boards or do i leave out the the hardi and ditra over the ply. Will i need to ditra over the joint between the two substrates ?? please can some one point me in the right direction ta muchly !!!
i can't see any need for ditra there but after levelling the concrete side and strenghthening the floorboards you will need to have a transition/grout joint between the 2 substrates. i've done similar using coloured silicon to match the grout
I did exactly the same this week, opus pattern floor that went into a new extension. Got matching Mapei Silicon to use as a movement joint across the doorway
confused.com
Tags Tags
usa
davebates,
peteablard,
davebates,
peteablard,
