Ruth
The project is to lay pale limestone tiles, 12mm thick onto ply (have followed the advice with primed 18mm ply firmly fixed to boards) using Ardex 7001 flex adhesive. I have tried to figure out the next stage ie actually laying the tiles but am getting confused. I know it must be a thick bed solid bed method, but not sure exactly what that means. Do I spread an even layer of adhesive with a solid trowel then go over it with a rounded notched trowel, pressing right though to the board or leaving a few mm of complete coverage of adhesive? Does a 10mm notched trowel have a notch depth of 10mm and width of something greater? Is 10mm the correct size? (tiles of different sizes, largest 610 x 406, smallest 200 x 200)
I am aware of potential issues of permanant marking on the surface of a limestone tile if the under surface is not entirely covered with adhesive. I have read of back buttering the tiles, I presume this means spreading an even layer (assuming the tiles are flat) of adhesive before laying the tile. Is this necessary (I'd have thought more room for variation in adhesive thickness) or will they be sufficiently covered when placed (with a firm twist) onto the trowelled base? If so, how thick a layer?
Finally sealing the tiles, I thought it might be easier and safer to put one coat of sealant on the tiles before they are laid (LTP impregnator), is there any reason not to do this?
I really appreciate your advice, I wouldn't have got this far without it!
