Connectors for T&E to Singles. Discussion ThreadConnectors for T&E to Singles. Electrical Advice
I’ve a job to do at home. I’ve a feed that connects my house to the garage consumer unit. The cable is in 10mm T&E.
I’m replacing the conduit for galvanised and spraying it white to match the render.
I was thinking where it exits the house in an end box rather than struggle with the T&E I was going to use 10mm singles instead. But is there connectors that anyone would recommend to join the cables? Or would good old connector block be okay?
Connectors for T&E to Singles. for the original thread on Electricians Forums
