Discuss Corner finishing in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Hello and welcome..
You can get corner finish trims like these from schluter..
Schlüter®-DILEX-EKE/-EF
Schlüter-DILEX-EKE and Schlüter-DILEX-EF are single-part corner profiles for interior wall corners. If the floor covering is not constructed as a floating screed, Schlüter-DILEX-EKE and Schlüter-DILEX-EF may also be used as flexible floor/wall transitions. The trapezoid perforated, lateral anchoring legs are firmly embedded in the adhesive below the tile covering. In the case of Schlüter-DILEX-EKE, one of the anchoring legs forms a chamber for inserting cut tile edges. In the case of Schlüter-DILEX-EF, the tiles abut the profile from both sides, leaving a uniform joint space. The tile surface can be either flush with the profile edge or up to approx. 2 mm lower, which allows for choosing a variety of tile thicknesses. Completely fill the joint between the profile and the tiles with grout (or partly with tile adhesive during installation). The visible movement zone is only 5 mm wide. It must be verified for individual projects whether this 5 mm zone is sufficient for the expected movements.
Schlüter-Systems UK Homepage +44 (0) 1530 813396 - Schlüter-Systems
Big-Smudge
Does any one know an alternative to Silicon for internal wall tiled corners, (gaps a little big), is there a product similar to normal tile trim used on windows etc? that could give a clean finish:oops:
This is my first post so I hope its OK and you Guys can help
Cookcroft
Have a look at this, its a little low quality (for the time being) but it shows how to use cornertape around a bath and more importantly how to do those tricky 3 way corners easily with cornertape.
[ame=http://www.youtube.com/watch?v=QEj_GzgJGDk]YouTube - How to seal a bath with cornertape and Silicon. www.nofinger.co.uk[/ame]
Cheers
Andy
beanz
Berkshire
Thanks to all for the advise, I decided to remove a number of the tiles and replace with better sized ones, this followed by a neat Silicon join into the corner,(should have done it right first time!! )
Cookcroft:hurray:
hehe! My first job, i had two tiles with about 4mm gap on the bath, that i hadn't noticed til taking the quilt off the bath; i was gutted! Wanted to knock em out and re-do, especially as the Silicon was being done by a Mastic Man. Customer wasn't having any though, as i'd already been in there a week... I think he was fed up with feeding me Bacon Butties lol!
Reply to Corner finishing in the British & UK Tiling Forum area at TilersForums.com
Hello: First time posting. Looks like a really good forum for Info. Here is my question: I'm...
Tiling three walls where sink will go. Walls to left and right of sink will have tiles up to...
Hi, Planning on tiling with a "border tile" along the top. It's an inset area with a sink, 2...
Corner finishing
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
