Discuss CornerTape - Internal Corners in the British & UK Tiling Forum area at TilersForums.com.
Big-Smudge
Hi Guys,
We've come across a few guys that have used cornertape and thought that it can only be used on straight runs, this is not the case.
Cornertape makes a perfect internal 2 way and 3 way corner very easily and it takes about a min to do this. The joint is then formed from one piece of Silicon so there's no join to go mouldy.
Follow the link below for a step by step. I've included every step but its so simple, mask the corners first then do the long runs of CT into the pre masked corners and simply overlap it.
No measuring, No mitreing, and No skill , just a little product knowledge the same as every product you use.
Simple and perfect 3 way corners
Hope this helps a little,
Your comments are welcomed , good or bad.
Cheers
Andy
Reply to CornerTape - Internal Corners in the British & UK Tiling Forum area at TilersForums.com
  • Sticky
TilersForums.com has been online since 2006 and we've had many designs, even three forum...
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
    • Winner
As the title suggests, Schluter have just unveiled their new advanced wet room course at their...
9K
GoneGuy
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
