Discuss Correct Adhesive for plywood in the British & UK Tiling Forum area at TilersForums.com.
brian c
Always read the manufactures instructions....to see how they recommend priming the ply....
Dave, what other way is there to prime ply m8?Do you mean the adhesivbe manufacturer and not the primer?Always been told to prime ply to seal ply so it doesnt absorb the moisture from the adhesive...confused me a bit m8.
GazTech
I was of the opinion it had to be 18mm ply to use SPF otherwise 2 part would be needed?
Turkish
This is correct if you wish for a guarantee. Dave also points out that back and sides have to be sealed with Bal Bond SBR prior to fixing down. These are recommended for our adhesives, some will differ regards priming surface, read instructions or ring manufacturer if in any doubt....Gaz
:yes:
Reply to Correct Adhesive for plywood in the British & UK Tiling Forum area at TilersForums.com
I'm about to tile my kitchen with 600mm x 600mm porcelain tiles. I am tiling onto a subfloor...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
