Discuss Correct Conduit Assistance Electrical Advice in the Electrical Advice area at TilersForums.com.
Correct Conduit Assistance Discussion ThreadCorrect Conduit Assistance Electrical Advice
Hi, i have built a log cabin and now routing cabling. I want to do this on the outside as it looks better. Can i ask if i can safely use the conduit from toolstation, here... 25mm Heavy Duty Round PVC Conduit - https://www.toolstation.com/25mm-heavy-duty-round-pvc-conduit/p66251
It has to be signed off by an electrician and from my research must be IP54 atleast. Is this correct? The conduit linked above has no IP rating, only the flex conduit does. Which is fine if i have to use that. The junction boxes don't seem to have a IP rating so now trying to understand what to use.
www.toolstation.com
25mm PVC Conduit Box
www.toolstation.com
www.toolstation.com
Is it a case of purchasing the rubber gaskets and this then makes it IP54 or above?
Apologies for the daft question and appreciated any help.
Correct Conduit Assistance for the original thread on Electricians Forums
Reply to Correct Conduit Assistance Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
