Discuss Correct float and adhesive for concrete / durabase in the America Tile Forum / Advice Board area at TilersForums.com.
Hi All. Ive done some research which has confused me more than when I started reading. So thought id post for some advice.
I have a poured concrete screed floor with UFH, its been down 18 months with UFH on low. The surface has been sanded as it had a sheen when it first cured. Im wanting to tile it (have tiled walls before) but wanted to do it right. As such ive purchased the tiles and membrane but have a couple of questions.
1. Theres quite a big difference in price between Mapei Keraquick Wall & Floor Rapid-Set Flexible and Mapei Rapid-Set Flex Wall & Floor Adhesive. Which should I be using and why? Im not averse to the cost if its necessary but I cant tell what.
2. Based on the above, do I need to mix in latex?
3. Ive bought durabase anti-fracture membrane. Can I use the same adhesive as above? with 3mm trowel
4. My tiles are 150x600mm food effect porcelain. what size trowel notch should I be using?
5. The screed is level, smooth, clean and dry. Ive washed it and vac'd it, do I need a primer or will I be ok?
I will be tiling at my own speed in small batches as I know the adhesive can set up quickly.
Thanks for the advice.
Took a guess and worked it out myself.
6mm square notch trowel that collapses to 3mm
Mapie primer G
I tried both adhesives in a test spot and were solid so went with cheaper one.
used the same adhesive for matting as well as tiles.
Did a test spot for the tiles, used same trowel and back buttered. Took tile off and had collapsed niclely with about 4mm of adhesive layer.
Cheers
Reply to Correct float and adhesive for concrete / durabase in the America Tile Forum / Advice Board area at TilersForums.com
Hi Guys i’m going to be tiling over skimmed plaster walls in a kitchen for first time. (first...
Hi all, Finally getting to lay the tiles in our renovated kitchen tomorrow. Tiles are 450x450x10...
Pro help please... i have a large outside area 6msq approximately...ive just had a concrete...
Which tile adhesive should I use for 60x60cm porcelain floor tiles? The floor is concrete that...
Can I trouble some experts in here for some advice on laying pavers on a concrete pool surround...
USA Tile Forum Popular
America Tile Advice Trending
uk
What member type are you?
  1. Homeowner
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
