charlie1
Hi all,
Watching cowboy trap this morning, I only seen a wee clip of it as I was working so don't really know the whole story, however the bit I caught was about the floor tiling that failed! so the they realised probable cause was the tiler used 4mm plywood to overboard the floor!! So he kind of showed you why not to use ply this thin by flexing it then advised you should be using 9 mm ply instead !! wtf!!, I thought b'standards where 18mm, I personally use 12mm in most cases! ,and never use anything less!
