N
natalie stanley
Hello
I was hoping somebody could help me as both my bathroom and kitchen floor tiles are cracked.
These were both laid in October last year. I'll address both floors separately as the tiles are cracking in different ways/places.
Bathroom
This floor is cement encaustic tiles and i first noticed a cracked tile around December so 6-8 weeks after it was first laid.
The first tile i noticed was closest to the wall and since then there are now 10 tiles that are cracked all over.
Kitchen Floor
This floor has porcelain tiles and late January i started hearing loud popping noises. 6 weeks later i noticed 8 cracked tiles all in a row with a crack running through the centre of all of them - this also happens to be where the joist line is.
There also felt like there was some movement in the floor, particularly to the right side although this seems to have settled a little. There is also a gap between the bottom of the skirting board and floor which is around 8mm which never used to be there when the floor was initially laid. I feel like it's sunken a little - all observations ive noted for the kitchen have stopped or at least i think it has. Theres no more cracked tiles and the floor hasn't sunken anymore.
I must also add that the builder was also responsible for not only laying the tiles but building the substructure/joists that the floor tiles go on as he had to replace the joists from before as they were rotting. He's used 18mm ply on top of joists and tiled directly onto them using flexible adhesive.
Any help or advice would be greatly appreciated.
Nat
Bathroom
Kitchen Floor
Nat
