Discuss Cracked glass tiles in the British & UK Tiling Forum area at TilersForums.com.
K
kingborris
Hi All,
I've recently had a new bathroom installed and had the shower cubicle lined with 20x20cm glass tiles. This work was done by an outfit doing a whole host of renovation work on the property. The work was completed and I was happy with the job done.
Around 2 months on, and before the shower has even been used, 4 of the tiles on one wall have cracked right across. The wall in question is at the front of the house and is therefore a load baring wall. It was a brick wall covered with plaster before it was tiled.
Does anyone know what is the most likely cause of the crack? Is this down to poor installation or is there something else likely to be the culprit?
Does the installation of tiles like this require any special techniques, as AFAIK, they just treated them like the regular ceramic tiles the rest of the bathroom has been tiled in? I've not had a problem with any otehr parts, just the glass tiles.
Any information / thoughts you have are greatly appreciated.
Cheers,
KB.
K
kingborris
Hi,
Thanks for the responses. No pics until tomorrow unfortunately.
The tiles were from the same range as these, just in a different colour:
Tile Range - Crystal
I'm pretty sure they used a granfix adhesive, but i'm not sure i could tell you which variety was used.
Oh, and the plaster on the walls wasnt new. the wall in question used to be a small bedroom we have converted to an ensuite. The plast originally had wallpaper over it, but itself probably is still the 50's original.
K
kingborris
Finally have some pictures.
Any comments welcomed.
UKTT Darren
TF Official Sponsor
Subscribed
195
828
North East
Hi Mate
There should be an expansion joint in the corner and filled with Silicon, if the tiles have been butted together and there has been some movement in the house or walls then theres your problem, another cause could be the adhesive has shrunk as its dried which is normal when the water comes out and the glass tile cannot take the stress of it
There is two explinations
K
kingborris
cheers for the replies.
its a 50's brick built house.
if we replace the cracked tiles, is this likely to happen again? Would it take much movement to cause this? I'm a little concerned now as we had a full survey done on the property before we bought it, and there wasnt any indications of movement. we havent made any alterations to anything structural in the house, just removed a non load bearing wall in anotehr area and knocked a door through another non load bearing wall (actually the wall adjacent to the wall with the cracked tiles).
So i'm guessing the people who did the tiling cant be held accountable for this?
Reply to Cracked glass tiles in the British & UK Tiling Forum area at TilersForums.com
Help please from any tilers. The plumbers made a mistake and had to rerun pipes after...
Hello, Anyone got any left over tiles need 2 to repair a client shower installed in 2014. Tile...
Cracked glass tiles
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
