Discuss cracked screed in the Australia Tiling Forum area at TilersForums.com.
GetAttachment (2).jpg GetAttachment (1).jpg Not the best pics but the crack is just to the left of steel.
Stef
yes it is steff, it is all solid though
I'm having a bit of bother with one myself just now.
The plumbers had used egg board to clip the pipes in & the screed guys weren't happy, they had to weigh it down initially with concrete blocks as it started to float but once the screed was poured it held it down but they never took the blocks back out.
They tried to take the blocks out next day with hammers & cracked the screed, it's not too bad & is solid so I'm going to take a chance & tile it, not ideal but spoke it through with the owner/builder & he's happy to go with it.
I would let Alan deal with this one as he's the man when it comes to this type of screed.
Ajax123
1,213
Lincolnshire
If there is vertical movement it will need to be repaired. If there is no vertical movement then you could just use an uncoupling membrane. Wherever screeds crack I would always encourage get uncoupling anyway as you never know if the screed will crack further when it's heated.
Dave
Staff member
Subscribed
389,930
1,000,000
Co.Durham
That's not always possible with wet ufh , if the crack isn't wider than 3mm or likely to open above 3mm then a crack matting will suffice don't you think Al..
Reply to cracked screed in the Australia Tiling Forum area at TilersForums.com
gamer1
Heeelp!!! I've seen some old posts about this but nothing recently. I have 120sqm travertine...
Had wet system UFH installed on a concrete subfloor to the whole ground floor ie living room...
Poynton, cheshire
cracked screed
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
