Boondocker
Afternoon all. Have recently said hello to theforum and finally got around to posing some questions on a bathroom refurb.
Firstof all, having removed the 30 year old cappuccino coloured bathroom suite withmatching tiles I am left with plastered walls that have a nice selection ofcracks across them.
In oneof the photos where the wall has been channelled out to accept the edge of abath you can see the vertical crack goes through the plaster and in to theblock work (it does not go all the way through to the other side). You can alsosee that the bonding and plaster has not adhered to the wooden plate upon whichthe block work has been built.
Myintention is to put a low level (40mm) shower tray with pumped shower where thebath used to be, tile walls and floors with 60 cm x 30 cm glazed procelaintiles (21kg/m2).
Firstly,any opinions on tiling this wall? Any backer board, Orbry, Marmox, Kerdi etcwould have to be dot and dab. As the max load for plastered walls is 20kg/m2 itcouldn't bear the weight of backerboard plus tile/grout/adhesive. So, alsobearing in mind the wall's condition would mechanical fixing through to theblock work be the only option?
Thefloor appears to be sound and level. All original flooring has already beenripped out and is to be replaced with 22mm WPB marine ply,then Ditra Heat matand then tiled.
Soundslike a simple plan after all the thinking and if I don't get a move on then myother half will be restricting bedroom access until it's finished!
Allcomments and criticism gladly accepted.
https://www.dropbox.com/s/pjfv0ogp4wy3x1d/bath wall3.jpg?dl=0
https://www.dropbox.com/s/x1tgdaa26cdqj1i/bath wall 2.jpg?dl=0
https://www.dropbox.com/s/53wubeihtl1mhol/bath wall 1.jpg?dl=0
