Discuss Cracked tiles on UFH in the Australia Tiling Forum area at TilersForums.com.
Hi,just need some advice,I did a bathroom 10 months ago and have just got a phone call from the customer saying that 6 tiles have hairline cracks,been to have a look and 3 tiles have cracked on either side of the heating mat.The floor area is 4 m2 but the mat is only 1 m2 in front of the toilet,the customer supplied the tiles (from Wickes) and he prepared the floor with NMP and then the UFH mat before I tiled.Being a small mat I just tiled direct over it using Mapei flex, and tiles are stuck solid.My dilemma is once I remove the tiles I am bound to damage the mat,as I never supplied or fitted the mat would it be down to me to replace the UFH mat at my expense ?.This has never happened to me before and cannot see this is down to fixing error as the floor is solid,any advice would be grateful,thanks.
Just a normal cheap ceramic ,I have done a lot of floors with ceramic like the tiles that I used over UFH never with an issue ,I have said I will remove without charge but if I damage the mat which I reckon,that will have to be renewed just dont want to be at my expense and it will bound to happen again.
Spare Tool
I too have had a problem with using ufh with nmply, and they wernt ceramic, cracks appeared in granite after about a year. On lifting a few i found the cracks were directly in line with the edges of the nmply boards, the nmply was glued and screwed and glued together on the edges. If you had leveled over the mat before tiling you might have got away with lifting the tiles carefully, cleaning up the adhesive, thin slc, fitting ditra or similar then retiling as i did, but in this instance i wouldn't have thought the tiles will come up without ruining the mat. On my job i got the customer to supply the new materials and tiles and i provided the labour free of charge. It was a local job in a small village and it kept my reputation intact to offer free labour.... No problems since
Sean Kelly
1,068
Ruislip
You will damage the mat when lifting 3 tiles. By pulling up on the tile you will probably stretch the cable. I tried to save a customers UFH mat a few years ago when she had her bathroom re done. It is virtually impossible unless you dot and dabbed!!!!!! (Joke - sorry!)
What's to say you did manage to replace 3 tiles. You will probably need to change another three by Summer.
You will have to go back to the customer and explain about his prep work and his materials. I guess supplying the labour free will put your mind at rest, but I would not be replacing items I did buy.
Was this job done on a tight/small budget? Did you offer to lay SLC?
If it was a bigger room and there was no option but to smash up 3 tiles, and you did stretch or damage the cable then a repair will cost £360.
Reply to Cracked tiles on UFH in the Australia Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
Hi, I have 45m2 of 1.2 x 1.2 Mirage 9mm floor tiles to lay. Never done this size before. I’m...
Hello I’m in Hampton SW London and have a floor problem. Wunda UFH water heating was installed...
Broadstairs,Kent.
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
