Guest viewing is limited
Discuss Cracked Tiles in the Canada Tile Advice area at TilersForums.com.
jobdone
543
Chobham
Had a call back to look at a job this week to look at a vertical cracking that has appeared in the wall tiling.
The tiles are 600 x 300 porcelain. The cracks looks like it is on a board joint.
All the walls were new moisture pb and additional studs were put in to 300 centres the job was completed 14 months ago. The strange bit is there is an identical cracking on the opposite wall. There are no cracks on the other side of the stud wall in the plaster or ceramic tiles.
I'm not sure why this would have occurred.
Any thoughts would be appreciated.
Time's Ran Out
Until someone tells you it's your fault, I'd do nowt!
We had to tile a new plaster wall in a bathroom and 6 months later they got the firm back to repair 2 vertical cracks 30" apart. How were we to know there was a blocked up doorway behind - it was just a plaster wall to us!
Had a job 20 years ago where the timber floor cracked on 8 foot boards - is it my responsibility to get a structural engineer in even when I'am not told about the 2 ton of granite going on the work tops.
Sometimes other people are to blame not just the tiler!
Reply to Cracked Tiles in the Canada Tile Advice area at TilersForums.com
  • Sticky
5K
Matthew7
jobdone
Chobham
Business Name
MPT Bathrooms and tilling
Cracked Tiles
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
