K
kaharrison9
Hi all
Your thoughts would be appreciated.
Been to look at a wetroom bathroom in an exstension that was built around 7 months ago and has now gone horribly wrong.
The builder whose built the stud walls for the bathrooms hasn't used any noggins and has just got vertical studs that he has then screwed 12/15mm ply upwards at about every 650mm.In a small area that has still to be tiled the end of the ply doesn't even fall onto any wood and as you come up the stairs theres cracks where the ceiling meets the wall.At first thought it was structural but when reached up can actual push the stud wall.
Next,the customer has decided to tile the wet room himself,Used a unknown tubbed addy(tiles 300x100)no tanking at all,grouted into the corner which has now cracked,poor set out,on one wall tiled from the ceiling down for a mirror and when the wedi board was fitted and he has tiled the floor there is now a 3mm step onto the wedi board which he uses a squeege to push the water into the gulley:yikes:
Himself and his wife were woken by bangs and went to investigate and there were 3 4-5ft seperate hairline cracks in the tiling.
He admits he's made a right mess on his part and is looking at it been redone and also wants to avoid a repeat in a second bathroom.
The 3 cracks appear to be where the stud uprights are.
Is the likely cause of these cracks to be temperature/humidity exspansion and contraction where the 2 ply ends meet?or a weak wood frame poorly screwed and there's movement? or any other suggestions.
What's thoughts on having ply on walls especially bathrooms,i would never had considered it but the bal book explains how to tile onto ply?
The reason the builder used ply was he said when tiling onto plaster board the card pulls off and i'm sure he probably hasn't heard of a cement board.
Had the background been differant anybody think the cracks would still have appeared.
Cheers
Kev
Cheers
Kev
