Guest viewing is limited
Discuss Cracking Up! in the UK Tiling Forum area at TilersForums.com.
Mike
Morning
I have just had a stud wall tiled and when the tiler was grouting he noticed one of the tiles had a hairline crack in top corner. He replaced this only to find another tile and cracked in exactly the same place. Any ideas why this has happened anyone? Would it be a fault with the tiles? The stud wall shifting or a heavy handed tiler? Thanks
:welcome::welcome: . sometimes a damaged box of tiles would have a crack run through most of the box in the same place but it's strange they've not broke when laying them . good luck
Time's Ran Out
as the cracks are all i n the same place you had a box that was damaged in transit tell the supplier!!
Once they are fixed you have no recourse with a supplier!
You should have no cost of having it replaced again if it is a faulty as it would be down to the tiler.
And this time check the sub surface to make sure there is nothing to be transferred through to the tile - Good luck.
Reply to Cracking Up! in the UK Tiling Forum area at TilersForums.com
  • Sticky
6K
Hi, I recently purchased my first property and the existing kitchen floor porcelain tiles were...
Cracking Up!
