bunchofapes
Hello
I am wanting to relay my original Victorian tiled floor. I have around 80% of the tiles.
I have researched the manufacturer to be Craven Dunnill, but getting the missing tiles remade is expensive, so I searched for an alternative and found some that I can cut to size and intermingle with the originals as the colours match pretty well.
The problem is that the original tiles are 12mm thick and the ones I have found are 9mm.
I have done a reasonable amount of diy tiling before, so really want to attempt this!
My question to the forum is: To thicken up the tiles, would it be reasonable to make a jig 12mm thick to hold a 9mm tile and then top up to the 12mm with a suitable tile adhesive and let it cure, thus giving you a 12mm tile of sorts??
I am not sure if that is madness or indeed if it would work!
And advice or suggestions would be appreciated on how to go about this.
Many thanks for reading
Dave
Dave
