scottmcgaw5
Hi all, have tiled small areas before but trying to create a wetroom.. I have read a lot of tips etc on here so far.
I am creating a bench within an enclosure which I want to create a steam room in. Floor to ceiling glass, and I plan to put an long drain butted against the wall under the shower, creating a slope for the water to run to. 1600mm length with 20mm slope, 1000mm in width, my tiles for this area are 1000mm wide which will help, but my thought process on the slope is unsure.
I was thinking of using 3 sizes of ply , 530mm length each, starting with 18mm, then 9mm, then 3mm to create the slope. My plan was to cut the floorboards away, support the joists with noggins, adding multiple noggings at the 3mm part to completely support the area.
Is this something which would work? I will be laying q-board/jackoboard on top and Sealing.
What's your guys advice on this?
Also for the q-board, I have read 10mm is OK, then elsewhere I have read 6mm is OK. My plan for the rest of the bathroom was to leave the 20mm floorboards and put 3mm ply with dpm then put the q-boards on top and seal.
Let me know guys, in my head this works, but would like an opinion or 3 lol.
Cheers
Cheers
