clenched buttocks
I wondered if I might trouble you guys with a bit of advice on creating an access panel for a bath.
The existing bath panel is unfortunately is tiled plasterboard. Following a leak it was necessary to remove a section of this panel to get access. Now the problem is resolved I would like to create an access panel. I would presumably need to fix a vertical batten where the cut section ends to support one edge of the new panel. It is probably easier if we were to use a piece of white mdf for this as creating a tiled panel is likely to be rather complicated.
Any information on how to go about this would be much appreciated.
