Hello all.
It's close to crunch time, and after having read lots of advise from the site (it's not fair to single out individuals when there's so much good stuff here, but many thanks to wetdecs for his postings)
I've got a bathroom & a wetroom to tile.
The bathroom is on the 1st floor, with green plasterboard walls and a 25mm OSB floor on oak beams (I'm guessing they must be about 6" square) running the length of the bathroom (about 3m) with a solid stone wall supporting 1 end, and a 12"x10" oak beam supporting the other. The beams are on 60cm centres.
The bathroom is actually a shower room - no bath in sight. The shower tray is a low profile stone/resin placed directly onto the OSB with a hole cut for the waste.
The floor tiles are 34cmx34cm porcelain from a decent tile shop. The wall tiles (for the shower cubicle & basin splashback only) are 60cmx30cm ceramic from a DIY shed (Wickes ... I know, I shouldn't have, but it's too late now).
I'm planning to cut the floor tiles into the quadrant tray, cutting the curve with a Marcrist CC750 on my little angle grinder. I haven't decided yet on 45deg or square, but probably square. The w/c & basin pedestal will be placed on top of my tiling. Planning to prime the OSB & then use BAL Single Part Flexible with 3mm spacers and a BAL Solid Bed trowel (half moon type).
Q. I'm not planning to tank the floor. Is this OK?
For the shower cubicle, I'm planning to use silicone to seal between the tray & the plasterboard, then tank with BAL WP1, with 10cm tape for the corner, before tiling with the tile horizontal & a 2mm spacer.
Q. Do I use the tape to try to get a small lip from the wall over the edge of the tray?
Q. The BAL instruction is to use either a brush or a trowel to apply the stuff. Any advice on which is easier? I've got a nice stainless plastering trowel - would the WP1 ruin it, or is it a good choice?
I plan to finish walls & floor with BAL Superflex, with silicone for the corner joint & tile to tray joint.
Q. What gap should I leave in the corner & between bottom tile & the tray?
I'll post my plans for the wetroom later ... time to get back to work.
(and I'll post pictures as & when I start to make progress)
