Discuss customer wants to ply over piped ufh in the British & UK Tiling Forum area at TilersForums.com.
doug boardley
I'll just run this by you guys. Went to look at a job last week and customer has had piped ufh installed and screeded over, but only just over, you can see the top of the ufh through the screed. Embedded within the concrete screed are whate appears to be 2"x2" wooden "joists" to fix plywood,9mm:yikes: to. What would you guys do,
remove the wood and fill with concrete and slc (poss 2 part) over?
or maybe a ditra type uncoupling membrane over it all and tile as normal?
:20:
White Room
I think he is planning to remove the wood if he uses SLC. At least that's what I was thinking
Fair comment Matt, just reread the thread and your right about the wood, If I removed the wood and filled with screed which will shrink back, then slc on the thin side, then decoupling
Reply to customer wants to ply over piped ufh in the British & UK Tiling Forum area at TilersForums.com
Hi, I am trying to achieve a low floor build up including wet UFH over a new suspended timber...
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
Heeelp!!! I've seen some old posts about this but nothing recently. I have 120sqm travertine...
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
