Discuss Cutting 50x25x10mm Porcelain Mosaic in the UK Tiling Forum area at TilersForums.com.
jgw1
Hi all,
I am about to tile the backsplash for the kitchen. I chose 50x25x10mm Porcelain Mosaics in 30cmx30cm sheets.
I have tiled with 600mmx600mm porcelain floor tiles before and ceramics in my bathroom but not porcelain mosaics.
I am planning on using BAL Grip as I don't think I need a powdered adhesive here (unless you guys say different).
My particular worry at the mo is cutting. I have a basic powered (wet) and non-powered tile cutters but don't know what the best way to cut the mosaics is. With the porcelain floor tiles the wet vutter tended to chip the top surface of the tile which I could hide but that's not the case here.
Any advice on the best way to cut porcelain mosaics - are they as tough as the floor tiles?
jgw1
OK,
What's the gripe with grip :)
I used various BAL powders and I am fine with them but for the splashback I thought Grip would be OK. Is there a better ready made adhesive for mosaics that you guys recommend or is it powders all the way?
I'll check out the diamond wheel price, I only have 4sqm though so it could add 25% to the cost of the job. If not I'll get some heavy nibblers with my addy.
Rich
Tradetiler Tile Hole Cutting
They should be ok, but you could find that your mosaics are a bit hard for them, these are are what I would use as they are better at going through harder tiles but slightly harder to use as the 1s from topps have a flat edge so they are easier to get a clean straight cut.
With either of these nippers I would score and then bite to the line using the nippers. :thumbsup:
jgw1
For future reference.
I bought a pair of heavy nippers from Topps which were rated for porcelain but the tiles were too thick (actually 12mm thick). The nippers could clip the tile but the amount of work needed was unfeasible.
So I upgraded by motorised tile cutter blade and used that. That was fine although I had to do the cuts dry as water activated the mosaic webbing glue.
Thought that this may help people in future if they have the same question.
Reply to Cutting 50x25x10mm Porcelain Mosaic in the UK Tiling Forum area at TilersForums.com
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
Hi everybody, I am about to lay my patio, 60x60cm porcelain tiles. I have just checked on where...
Hi, I'm tiling the floor of a wetroom and would like some advice on the best way to lay the...
