Stevev
This may seem and odd question...but when I did a tiling training course, we were taught when cutting out say a piece to make a tile look like an "L" ie cutting block out of a corner, was to use a wet cutter to cut shortest cut and score the longest and use nippers to snap it off.
Due to getting tinnitus I want to use th wet cutter as little as possible....so, is it acceptable to score both cuts with manual cutter and use nippers to nip accros and down until I can snap the portions of....I cant say the finish is quiet as good but usually these cut would probably be siliconed over anyway or concealed under kitchen cupboards.
I guess I want to do it the old fashioned way. Is there a way of doing holes for pipes without drilling?
Is there a link to a youtube that can show me these techniques?
My tutor mentioned using parrot nippers but u still have to drill a hole?
Like I say I want to avoid using wet cutter and power tools as much as possible.
many thanks
many thanks
