Guest viewing is limited
Discuss Cutting marble mosaics in the UK Tiling Forum area at TilersForums.com.
I’ve got a job using marble geometric mosaics about 10 mm thick. I’ve tried several blades to cut these but every one seems to chip and break the corners off the tiles . wet sawing seems to be better but still the same problem.and almost impossible to see the lines. I’ve bought a Montalit dry /wet cutting disk, but still the same problem.does anyone have any advice out there ?
I’m going to buy some plastic strengthening Self adhesive backers tomorrow for the tiles, but is there anything else I should be doing that can help? Any advice appreciated before I wreck 2.5k’s worth of tiles!!
Reply to Cutting marble mosaics in the UK Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
Advice Hi guys, got some 60cmx60cm porcelain tiles to lay in a hallway with a modular pattern...
Bathroom being refurbished. A load of things have been rushed like some loosely rollered (not...
  • Sticky
5K
Matthew7
Shropshire uk
What member type are you?
  1. Professional Wall and Floor Tiler
  2. Contractor
Business Name
P.c jiggins
