Discuss Cutting notches in porcelain floor tiles in the Best Floor Tiles area at TilersForums.com.
Jackswan
I need to cut a notch roughly 100mm x 25mm on the edge of a glazed porcelain floor tile. What would be the best way to do this without chipping the glaze.
Cut small fingers with a wet tile saw or
cut the 25mm slots with a wet tile cutter then run a diamond blade in a grinder along the 100mm length?
If I did use a 4 1/2 blade in a grinder any tips for getting it straight?
cheers
Reply to Cutting notches in porcelain floor tiles in the Best Floor Tiles area at TilersForums.com
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits)...
I’m tiling a ground floor of a house approx 120m through a ground floor with 5 doorways in the...
ADVICE WOULD BE APPRECIATED. The room is 10M x 4 M and has a new 50mm liquid screed over wet...
Best Floor Tiles
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
