Discuss Cutting out tacos in marble in the UK Tiling Forum area at TilersForums.com.
TMTservices
Hi mate, The rotozip is good for plunge cutting. Cant remeber the exact name of the bit but the one I use will eat through the marble. Does not leave a fantastic smooth finish tho, and will have to cut slightly short and file to finish, using tape to prevent chipping. How far away from corners is it?There may be something easier you can use, Im sure someone will let u know if there is.
Aston
hi
i cant see the images either?
cant you just dry lay your 4 square tiles, then position your taco in place and mark around it, allowing for you grout line.
then set up a template as a guide so that you can run each square tile through the wet saw and it will cut in the same place or set up a similar template with a stop mark and then you could put your tile in place, stopping it at the set mark and then use an angle grinder if you havent got a wet saw.
Reply to Cutting out tacos in marble in the UK Tiling Forum area at TilersForums.com
Looking for some technical advice on these tiles please. Our installers fitted this CaPietra...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
Good day all. My daughter has asked me to tile a cooker splashback in her kitchen. They've...
Hello, as a novice, I need some advice. Our landscapers have been doing a fantastic job so far...
TF Group Please Join
