I am about to embark on retiling an outside passage at my home. I am going to use Wickes quarry tiles (mainly because they are cheap and I am tight). I will have to cut both sides of the passage to fit them in as I am setting out working from the centre outwards so it looks even when finished.
It means quite a lot of tile cuts. I normally use my 4" angle grinder to cut half way through and then break the tile. Other than buying a table cutter (Can't justify the price) is there an easier way to cut these sort of tiles.
