j@mes
Hi all, after a bit of advice on how to cut a notch in a 10mm thick porcelain tile. I have an electric wet cutter which is fine to put the two straight cuts in,(3mm) it's the final cut I'm struggling with as it is only 6mm wide so too small to cut with the electric cutter. Any advice welcome, I don't mind buying a tool to do this but not looking to spend a fortune as it's unlikely to be used again after doing two notches.
Any help and advice appreciated.
Thanks.
Thanks.
