Hi Jimmy,
You will need a wet saw for trav, but cut it dry If it is unfilled trav (Lots of little holes and air pockets) the dust will need to be blown out with compressed air before you fix. Same with honed trav it just stayes cleaner. Cutting it dry will lessen water staining and slurry becoming embedded into the pores of the stone.
I use a off white or white floor adhesive even on walls use a 10-12mm notched trowell and trowell the wall no need to back butter but wipe the back of the stone with a damp sponge first to remove excess loose dust.
I always seal stone after i've grouted.
[/quot
Hi
Aussie Mick can you clear up a couple of quieries for me -
When you say dry cut it do you mean don't put any water in the well of the wet cutter? If so doesn't it create issues with the blade becoming hot?
Also I thought you were supposed to seal filled/ honed trav before you grout to prevent it from staining the stone or can you do it either way round? Which is the best/safest (so as not to damage the trav) way of doing it?
I have seen travertine in topps that looks like it has been filled with resin - looks very beautiful and unusual. Would you seal this kind before or after grouting?
Thanks Mick - any other imput also welcome
