Discuss d&d board onto old painted plaster - and then tile in the Canada Tile Advice area at TilersForums.com.
Guitardedleon
in the bathroom I am doing its an ex council
the walls are bad ( pretty sure the council only employ monkeys )
house built in 50s
artex walls , then gone over countless times with fresh skim over the years.
this rules out hacking off for two reasons:
1. Artex
2. poured concrete wall
the only option is to d&d boards to the walls as is.
the walls are painted but i have gone berserk scoring them with an old chisel tonight
( looks like a maniac has been locked up inside )
in your opinion will this be sufficient to support:
d&d boards
tile addy
ceramic tiles ( full room height )
as the plasterer is due at 9am :yikes: and its only just occurred to me tonight about the paint
and i dont really fancy them falling off any time soon.
Andy Tiler
1,043
manchester
house built in 50s
1. Artex
d&d boards
tile addy
Dot n dab the walls but I would mechanicaly fix the boards aswell with hammer fixings..
Andy Tiler
1,043
manchester
cheers andy
I thought of using some mechanical fixings to help support earlier
reassuring to hear it from a pro!
in your opinion d&d and screws too should be good enough then?
Yes! I use the metal hammer fixings.try a company called Jackoboard!
Andy Tiler
1,043
manchester
Brilliant!
Thanks again Andy, plasterers due in the morning so will order the fixings tomorrow
do you have a link I can find them through as google doesn't seem to have much luck.
Here you go! give Colin a ring tomorrow and explain to him what your doing and I'm sure he'll
Help you out
http://www.tile-backer.co.uk
Mr Tiler
Yes! I use the metal hammer fixings.try a company called Jackoboard! 
hi andy those hammer fixings wont hold the board up unless washers are used is that correct mate? as once you nock the plug thrugh the board it will create a whole as big as the screw head am I rite? cheers
Andy Tiler
1,043
manchester
White Room
If your just using screws to hold plasterboard and if the head of the screw goes through the paper face then it's next to useless....
White Room
cheers havnt had the chance to do any dot n dabbing boards up yet.... mark what about when using drywall screws to attatch p.b to timber is that a no? ive done that a few times seems fine
Thats fine Ash but use course threaded screws which hold better to timber and again don't let the the screw head break through the paper face of the board...to add the screws should be 32mm.
Guitardedleon
sorry just read the last few posts, now I'm slightly confused..
once d&d to the wall and dry, i would use the fixings.
Andy, I take it you've used them before, how do you do it?
as my knowledge of PB is to have the screws just below surface to prevent trowel snagging
obviously with tiling its not quite the same as skimming
so are you able to leave the screw heads proud (as far in without breaking the paper)
and just apply your addy over the heads as normal?
Reply to d&d board onto old painted plaster - and then tile in the Canada Tile Advice area at TilersForums.com
Hello, I would start wit ha little back story. We've both a house where the main bathroom begged...
5K
Hi all, I have an issue I'm hoping you chaps can help me with after removing tiles from my en...
5K
1animal1
Hi All As above how do you remove 8m2 of gloss paint from a plastered bathroom wall(easily) I...
Aston
Hi all, First post, so please be gentle! Preping our bathroom to drag it out of the early 90s...
23K
Hi all, Going to be fixing 'no more ply' backer board to a mixture of wall substrates (both...
15K
SteUK
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
