magicman-alex
Hi All,
I've just ripped out my bathroom as the previous bathroom installation and tiling job was pretty bad and I figured it was a good chance to try my hand at tiling.
It's a 1st floor maisonette and I've suffered with leaks into the flat below due to a poor bathroom installation. I've removed all the tiles.
The bathroom is an uneven concrete floor, so I'm guessing self-levelling compound will be in order at some point. However, when I removed the bath, I found there's a hole in the concrete that appears to go into a void above the ceiling of the bathroom below. I'm not sure how best to fix this hole before applying the self-levelling compound. A mate suggested fixing an old tile over it and then pouring the self-levelling compound, but I'm worried that a tile might be too thick and will just complicate things.
The hole is probably about 15cm x 20cm and the concrete itself is about 25mm thick.
I guess I could probably screw or glue on a very thin sheet of steel plate or something like that, but just wondered if anyone had any better suggestions.
Thanks in advance.
Alex
Thanks in advance.
Alex
