Discuss damp wall in the British & UK Tiling Forum area at TilersForums.com.
F
fergie
hello everybody just a question on a job i am about to start.customers tiles are falling off around bath&shower pulled tiles of and wall is wet there has been no tanking system put on before tiling i was going to leave for a week to see if wall will dry out and if so will it be alright to tank and will it be ok if wall is still a bit damp custumer has 2 bathrooms so leaving to dry out is not a problem any advice would be helpful cheers
DHTiling
why use tanking around the bath??it sounds like the bath and shower hasnt been sealed properly.and the adhesive will be a standard pva based.remove the loose tile and allow the wall to dry,then use a waterproof acryllic based such as whitestar and seal between the tile and bath/shower :grin:
Whitestar is water resistant..not waterproof...:thumbsup:
And what tile adhesives have pva in them..?...
cheers...
DHTiling
the shower is actually over the bath the wall in question is a stud wall so i take it to be plaster board with skim over the top
It really depends on how agressive the damage is to the gypsum in the board..if it has been over wetted then it will be weak even when dry....cut out any damaged area's and replace..then use a tanking membrane such as schluters kerdi or durabase wp this is appplied with a rapid setting cement based adhesive...( prime walls first) and then use a flexible cement adhesive on top....
Application methods can be found here...
kerdi- Schlüter-KERDI - Schlüter-Systems
durabase- wetdecs.co.uk
cornish_crofter
i would take the stud wall down if its soaking wet and replace with backerboard or plasterboard and tank it,then fix tiles.:thumbsup:
I would agree but I wouldn't have plasterboard as an option around the bath.
Spend a bit of time getting the wall straight and level on the timbers. It will be worth it.
Reply to damp wall in the British & UK Tiling Forum area at TilersForums.com
damp wall
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
