jonnyc
Just been to look at a problem floor laid by another tiler.
Anhydrite screed.
Very chalky latence not removed before tiling.
Screed not primed
dont know how dry screed was before decoupling membrane went down.
Back of alrge format porcelain not backed with adhesive.
Spot bedded with approx 40-50 % coverage to back of tile before adhesive debonded compltely from back leaving tile clean.
So plenty of mistakes , but im wondering what is the overriding factor for current problem.
Incidentally i cut through joints around tiles ,right through grout/adhesive and decoupling membrane.
Stuck a marble slab sucker on tile and pulled the whole sandwich of mixed fillings clean off the screed.
Me thinks that decoupling laid in flex adhesive will not stick to anhydrite if not dry or sealed or latence removed but logically i cant think that this debonding would physically detach adhesive bed from underside of tile.
There seems to have been some considerable pressure to make adhesive debond clean off back of tile , working on assumption right flex adhesive used.
This suggests to me that the voids in adhesive bed have caused some kind of uneven heat dispersion that may have popped the tiles.
I have heard of this before but never actually seen a case as such.
Only reason to post this is that i think this brings up the question in my mind about how one should fix a tile over underfloor heating.
The great unsaid word is that we all know that with rectified edges you cannot just bed a tile in a notch.
We have to overcome this problem by bedding out to suit.
Can be done in various ways but ultimately there will be a bed underneath that may not be full enough and what is that percenatge.
Anhydrite screed.
Screed not primed
