Discuss Decoupling membrane or not? in the UK Tiling Forum area at TilersForums.com.
simon87
I have a 5 x 5m new extension floor to tile. The floor is sand and cement screed laid 4 weeks ago with under floor heating. The UFH has been commissioned and is on, slowly increasing the heat to warm the screed.
My question is whether I will need to fix a decoupling membrane (eg Ditra mat) to the floor before I tile or am I safe to tile directly on to the screed. I appreciate it may be difficult to express an opinion without seeing the job but any advice would be much appreciated.
waterfd
Definately a membrane. You should also follow the guidlines about tiling on a screed with UFH. I was told allow screed to dry then turn heating on to relieve any stresses, this is with water UFH, turn the heat off and allow to cool. After tiling wait 28 days to allow adhesive to cure. Turn heating on to 5-10 deg alllow to settle for 3 or 4 days then increase temperature 1 degree per day until working temperature is reached. I presume this is the same for electric UFH.
Reply to Decoupling membrane or not? in the UK Tiling Forum area at TilersForums.com
Hi all, Finally getting to lay the tiles in our renovated kitchen tomorrow. Tiles are 450x450x10...
Hi, hoping for some advice.... Had a anhydrite screed laid early Feb. Looking at laying 20mm...
Hi, I had a small kitchen extension built a couple of years ago. The new sand and cement screed...
Hi Everyone. I'm after some advice with regard large format Tiles with water fed underfloor...
Tiberiu Curelaru
TF Group Please Join
