L
Leory
I am tiling a floor for first time on decoupling membrane ( durabase) is it best to lay the decoupling membrane on the whole floor even if I may not tile it all in the same day . Using anhyfix to lay the mat .
Discuss Decoupling membrane in the Canada Tile Advice area at TilersForums.com.
Not essential but i would. If you need to lift a tile to adjust the bed, it's far better if the mat is stuck down well!
Anhydrite floor? Sanded and vac'd? Moisture levels checked?
Yes anhydrite floor . Moisture levels checked with tramex in the room I'm starting in the levels were .8 in some areas where the screed was a bit thicker . Chose to use anhyfix in this room as tile masters said I could if the level was no more than 1 . Fingers crossed !
Reply to Decoupling membrane in the Canada Tile Advice area at TilersForums.com
