Perfect Tiling
Good morning. I am doing a job next week that I need a bit of advice on as I've never come across it before. Customer has a floor with piped water ufh covered with 30mm of plywood and tiles...as expected the floor hardly heats as ply inulates the ufh. The ply is coming up to be replaced with 22mm hardifloor boards. Tiles are possibly travertine. I usually use a decoupling mat under stone especially with ufh (usually within a screed) but hardiebacker say its not necessary and BAL aren't sure. Anyone come across this before. On similar note...if putting down stone on 10mm insulation boards with electric ufh would you use a decoupling mat...even if floors only around 6 sq mtrs. Ta.
