Discuss Delayed tripping on RCD Electrical Advice in the Electrical Advice area at TilersForums.com.
Delayed tripping on RCD Discussion ThreadDelayed tripping on RCD Electrical Advice
Not even sure where to start with this…
Got a split board RCD which is tripping after 10mins of being ON. Never had this before. I thought I identified the circuit with the fault (RCD trips immediately when circuit on) but looks like a fault on more than 1 circuit
Customer just had a brand new rewire, I don’t think I have seen it this bad before on a brand new rewire
  • Lights sockets no earth sleeving
  • CPC twisted together everywhere
  • No junction box used under floorboard. Cables just taped together or in some cases not
  • No glands In CU used for meter tails
  • IP rating for cables entering CU none existent, open holes everywhere
  • switch lines not correctly identified with sleeving
  • single core cable (blue) running in joists under floorboard between light switches
  • no isolator on bathroom extractor fan
  • earth cut at some switches
  • things incorrectly labelled at CU
The list goes on…..
I’m back there tomorrow to do more testing. My question is aside from everything wrong with the install, is there a scenario where a RCD will trip after 10mins of being ON without a light / socket / appliance switched on and off?
Delayed tripping on RCD for the original thread on Electricians Forums
Reply to Delayed tripping on RCD Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
