Tiling Tool Suppliers
Discuss Diagonal cuts on manual cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
Werz
Hi guys
I'm planning on doing some manual diagonal cuts with porcelain glazed, 600x600x10mm tiles. Problem I'm having is 95% of the tile snaps correctly along the score line but wonders off the line just before the end. This means I'm ruining one half of the the tile. I'm doing envelope cuts for a wetroom so would like to keep both sides of the cut. Anyone know how to keep the cut line all the way along?
L
LM
What cutter are you using and do you have it set correctly?
For envelope shower former cuts you should make them with a grinder with the correct blade or a wet saw as they take the thickness of the blade out of the tile and then that creates the grout joint that you will need and helps keep the tiles aligned better.
L
LM
Hi
I've got a large sigma cutter. I was planing on cutting the tile down the score line then carefully polishing 1mm off both pieces to make the 2mm grout line. Ive got these diamond grit polishing pads, which im told shpuld do the job. Will have wait and see if that works. First step is to do the diagonal cuts.
Have you a close up picture of the tile? A Sigma usually wouldn’t struggle with this type of cut providing you have scored adequately and have the height adjusted correctly. What model of Sigma is it? Is this a diy project?
Reply to Diagonal cuts on manual cutter in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
Beginner DIY Tiler, I'm contemplating drilling (with ceramic tile carbide tipped drill bits)...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Popular Tile Cutter Threads
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
