Discuss Diagonal Tiles on Floor in the British & UK Tiling Forum area at TilersForums.com.
m4ubs
I will be laying some porcelain floor tiles for a friend 33cm x 33cm. We haven't decided if were going to do it diagonally or straight line yet. I might do it diagonally as it looks better and coz i aint done a diagonal layout yet. I usually do a dry a lay and make a cross to get an idea of cuts and then adjust accordingly. I plan to do the same when i do it diagonally. Is there anything else i need to be aware of ?
E
enduro
I
IvegotsTILE
I just finished 23sqm,kitchen into dining room,really took my time setting out so you walked into the kitchen with a tile in middle of doorway and the dining room had like dh said a half diamond border around it.
Looked mint but took quite alot longer doing all the filling in cuts because you can't just offer the tile up as usual,I used the angle finder by ruby made life much easier,
Good luck with it mate
Reply to Diagonal Tiles on Floor in the British & UK Tiling Forum area at TilersForums.com
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
