Deleted member 1779
Did you know that at 365Drills we provide an in-house tile drilling service?
You can send us your tiles and we will drill holes into them. If you need a tile drilling service then we will use our brand PORSADRILL to cut a perfect hole into your porcelain tile, granite worktop, slate, glass etc etc.
At our premisis we have a dedicated radial arm tile drill. This is NOT a fixed pillar drill. Our unit has a movable boom so that we can reach deep into the largest of the large format porcelain tiles.
Using our radial arm tile drilling rig we can put a hole anywhere you specify into that large format porcelain tile.
We have a full selection of diamond core holesaws and tile drills and can basically drill any size hole you require.
We even have diamond core drills in sizes that we do not normally resell. For example we carry 123mm 13mm 7mm 66mm cores.
We can also drill in imperial sizes for the American market example 3/8 inch etc etc.
Using templates you supply we will accurately drill holes within a 0.5mm tolerance onto any tile surface.
We charge £60 an hour machine time (minimum one hour) plus the cost of the diamond core.
Shipping is £10 for the first 15KG and then £1 for every KG after that.
If you need to send us the tiles please ensure they are in a robust crate.
Please note we will return tiles in the same crate that you supply. Our couriers carry insurance for damage.
We have £2m product and public liability insurance.
