temptedtojoin
Hello, I am hoping somebody can give me some advice. I have had an extension built on my kitchen. This is nearly ready for tiling.
On one half of the room i have joists with old floorboards on, they have been removed and replaced with 18mm moisture resistant tounge & groove chipboard which is glued and heavily screwed down. The other half is 50mm screed layed over 100mm concrete with insulation under.
The screed is flush with the chipboard so at the moment the floor is all one level. This cannot be altered in any way as there is not enough door clearance, so tiles will need to be laid onto these 2 floors.
What i would like to know is would i need to use 2 different adhesives?
Where the surfaces meet can i overlap or do i need 2 keep the surfaces seperate? (there is one bit that is an l-shape which would make not overlapping difficult.)
One final question, the doorway to the room is about a 45 deg. Do i tile to the inside edge, outside, or middle of the threshold. This leads to the hallway which eventually will have carpet. Door opens into the kitchen.
(other information: tiles 333x333x8mm, porcelain. South facing room with 2 windows. Washing machine will be on chipboard end.)
