Discuss Different mosaic thicknesses in the UK Tiling Forum area at TilersForums.com.
L
Louise Renton
Hi, i want to tile a section of wall using a mixture of new and antique tiles/mosaics (unused). However i find that the tiles are of different thicknesses. How do i compensate for this? I was going to stick my selection of tiles onto a mesh backing first, as to lay them individually would be a pain (i think). Tiles are 5x5cm.
Rizzle from the Portizzle
put mosaic face down on flat surface between two batterns the same as the space they need to go in to when happy they are correct . then use apoxey resin on the back to set the boarder stiff wait for glue goes off then set in wall make sure you dont push the glue to far in to grout joints you may need to build this up in a few layers to take out the diffrent thicknesses
Gazzer
sadly, i was afraid of this....couldn't I just stick matchsticks behind the low ones as I glue them to the mesh? Or.....Mesh the bigger ones, leaving gaps for the thinner ones and then butter those separately and stick them down flush when i put the whole lot on the wall?
You could try , not something I have ever done though.
Reply to Different mosaic thicknesses in the UK Tiling Forum area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hi there I ordered 160sqm of 90cm x 90cms of matching Large Format Porcelain tiles. 105sqm for...
    Votes: 13 8.8%
    Votes: 11 7.5%
    Votes: 44 29.9%
    Votes: 17 11.6%
    Votes: 35 23.8%
    Votes: 20 13.6%
    Votes: 15 10.2%
    Votes: 7 4.8%
