Discuss different thickness tiles in the British & UK Tiling Forum area at TilersForums.com.
Andy Allen
1,318
Gloucester
i got to do a small poarch floor 4m2
the tile is a 100mm x 100mm hexaganal qurry tile with a black 10mm x 10mm dot in each corner.
problem is the quarry tile is 8mm thick and the dot tile is 3mm thick
instead of packing each dot up with addy i had a brainwave, a cheap 6x6 white tile from the sheds is 5mm thick, what if i cut them in to 10mm squares and used them as packers under the black dot tile.
good idea or am i being a numpty.
Reply to different thickness tiles in the British & UK Tiling Forum area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Hi there I ordered 160sqm of 90cm x 90cms of matching Large Format Porcelain tiles. 105sqm for...
gamer1
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi all. I hope you're well. I am going to be installing some 300 x 600 on walls and 600 x 600...
Andy Allen
Gloucester
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
