White Room
Had to check the tiles I am going to fix to walls and floor today. The samples were same length and would follow thru from walls to floor with the same grout joint. Checking the delivered tiles and there is a 2mm difference between the two tiles, Worked it out that the floor tiles need a 4mm joint and the wall tiles need 2mm to follow thru from wall to floor.
Anybody had this before
