Mossop
I was watching this tiling film, and from 9:35 it gives details of different methods of applying thin-set to the back of tiles.
Is thin-set just a term for cement-based adhesive? Perhaps this is an American term?
Methods are:
a) spot bonding
b) swirling application to wall only
d) directional application to wall only
e) directional application to wall with thin-set also applied to back of the tile
Apparently this last method is the best in bathrooms, which is the room I need tiled (floor & walls).
I hadn't realised there were different application methods. If getting a quote is it normal to ask which method the tiler will be using? Or does any reputable tiler directionally apply to walls and then also adhere thinset to back of tiles?
Methods are:
a) spot bonding
