Discuss Distance between meter and cut out Electrical Advice in the Electrical Advice area at TilersForums.com.
Distance between meter and cut out Discussion ThreadDistance between meter and cut out Electrical Advice
My main cut out and meter is in a small cupboard above a kitchen sink. The CU is in the utility room next door. The tails are approx 2 meters long. The DNO has said there is not enough room for a smart meter in the small cupboard.
Is it allowable to fit the smart meter next to the CU in the utility room as long as the tails do not exceed 3m? Or is there a max allowable distance from the cutout to the meter? I can't seem to find any regulations that apply.
Distance between meter and cut out for the original thread on Electricians Forums
Reply to Distance between meter and cut out Electrical Advice in the Electrical Advice area at TilersForums.com
TF Group Please Join
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
