Discuss DIYer doing 600x600 polished porcelein in the British & UK Tiling Forum area at TilersForums.com.
E
er.ronakshah
Hi there,
I am a DIYer doing the first and last job for my new house of laying 600x600 polished porcelain, just need to know how to lay the first tile itself, and i am thinking of using LASH leveling to avoid lippage, leaving 1.5mm gap for grout. since i have never done tiling what are the recommendations to consider while laying the tiles. is it advisable for the DIYer to lay the tiles to save money in labour?
Thanks in advance
regards
ron
peckers
We would need to know a few more things before we could advise really
such as:
what substrate is it going onto?
what adhesive and grout you using?
what is the area?
is there under floor heating etc?
some pointers for you!
make sure the substrate is prepaired correctly
adhesive and grout should be correct for the substrate and tiles
for that size tile i would use a min off 10mm u notch trowel
you may have to back butter/skim reverse of tile depending if back of tile has voids
substrate must be flat for this size off tile
polished porcelain tiles need sealing/unless pre sealed by manufacturer
joint sizes 2mm-3mm imo but depends on area? and type of tile? ufh etc?
Keep tiles and joints clean as you go
setting out take time setting out to get the best finnish possible
take into size of cuts etc
know where the last tile is going to end up before you start laying the first
tools required.
good quality dry cutter
good quality diamond blades to avoid chipping in wet saw/grindette etc
as to wheather you are confident in laying these tiles is upto you? if not and you want a pro job done in reasonable time and done right and once then you can post an ad on here for a tiler wanted and im sure someone in your area will reply.
Good luck which ever way you decide to go :thumbsup:
ps. if you decide to do it your self we love pics of it as you are doing it.
and if you have more questions then fire away..
E
er.ronakshah
Hello Peckers,
Thank you very much for such a good response,
Firstly I am in Brisbane, Australia so due to warm climate I don’t need under floor heated, more over it’s a concrete flat slab. Its been built by a good builder here, and its sort of very flat, any ways I will back check it as I go for the tiling bit by bit.
The total area I am covering is 140 square meters. I am using some, rubber adhesive which is ParexDavco: Australia
I was advised to buy this product from the shop where I bought the tiles from, about this product.
I will hire the dry cutter, and I have bought a small wet saw cutter with diamond blade.
Regards
peckers
hi, i dont know of the adhesive you have got, so i cant comment on the adhesive, there is a forum member on here called robz I think he is in australia and hopefully he will see this post and will be able to advise more as he would know the building/tiling practices out there.
The size of the tiles will make them heavy yes, and as with all adhesives they have to mixed correctly.if it is too wet then the tiles will just sink to the floor and you wont have a good bed under them. and if too dry you will struggle to achive a good bond and full coverage on the tile. hope this makes sense :thumbsup:
Matt
RobZ is from America. Jay is from Oz:thumbsup:
2020Tiling
Hello Peckers,
Regards
any jobs going ? iam looking for a sponsor ? :thumbsup: :8:
Deleted member 1779
If you are dealing with porcelain then we supply the diamond cores
Reply to DIYer doing 600x600 polished porcelein in the British & UK Tiling Forum area at TilersForums.com
This kitchen is not level as can be seen in the attached picture. From floorboard to kitchen...
Sid2323
Hi all, needed some advice. Can you fit kitchen floor tiles on a surface made level using a...
9K
Hi there I am going to be tiling my kitchen floor The kitchen floor has not be touched since we...
H
Hi everyone I've had some tiles for a good 9 months lying around waiting to be put up by my...
5K
Qwerty
Q
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
