Discuss Do I need to back-butter my tiles? in the UK Tiling Forum area at TilersForums.com.
E
essexsi
Hi all,
I have been reading a great deal on this website as I have a DIY job. I am fitting 600x300 ceramic tiles to the walls and 300x300 ceramic to the floor in a walk in shower that will be tanked.
I was all set, thanks to advice on here :thumbsup:, to use a 10mm square notched trowel for the adhesive.
However, I have been reading other threads which has confused me. The advice is that I may need to back butter the tiles and also use a round notched trowel. This is because of the tile size and that its being fixed in a wet environment.
I think it is because I have been reading too much I have info overload!!
Is back buttering where you apply adhesive to the wall/floor, apply adhesive to the tile, then fix the tile? Do I need to do it to either my wall or floor tiles? Still a bit confused round or square notch?
Thanks for any help. Cheers Si
doug boardley
back buttering is giving the tiles a ribbed bed of adhesive, back skimming is giving the back of the tile an un-ribbed skim of adhesive, these methods are to be used with normal spreading of your adhesive ie on your wall/floor. I use a round notch trowel on floors and areas that are subject to a lot of water, this is a solid bed technique. A square notched trowel is used in areas that aren't subject to drenching.
Hope this clears things a bit:thumbsup:
E
essexsi
Thanks for all your input.
As its a shower room the floor will be getting wet regularly, so from your info I will need a solid bed under the 300x300 tiles going on the floor. I will get a solid bed trowel.
Now with the 600x300 wall tiles I take it I will be ok with a 10mm square notch trowel with adhesive only on the wall, no back buttering on the tile. Correct? If it makes any difference there is a sort of profiling of small squares on the back of the tile. What I am trying to say is that its not smooth!
Thanks very much for your help. Si
Reply to Do I need to back-butter my tiles? in the UK Tiling Forum area at TilersForums.com
I'm having a nightmare trying to establish product info from distributors. For example...
Hello, Novice DIY tiler here looking for advice please. I'm replacing tiles in very small...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
