Discuss Do i need to issue a certificate Electrical Advice in the Electrical Advice area at TilersForums.com.
Do i need to issue a certificate Discussion ThreadDo i need to issue a certificate Electrical Advice
I'm an electrician, I've just fitted a heat pump to an isolator that was installed by another electrical company, I've been asked to issue a certificate for connecting the heat pump, I've gone back to them and said there electrician needs to issue the certificate as he installed the circuit, there electrician has gone back to them and said I need to as I've extended the circuit, I was under the impression that connecting to an isolator is not classed as altering or extending a circuit so I don't believe needs a certificate issued by me, am I right?
Do i need to issue a certificate for the original thread on Electricians Forums
Reply to Do i need to issue a certificate Electrical Advice in the Electrical Advice area at TilersForums.com
TF Group Please Join
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
